mchero
Nov 29, 2013Explorer
Here's someting to check on your "new to you" rig.
Make sure your NOT connected to shore power and the generator is off.
Open your 120VAC panel as well as the Xfer switch panel and check for loose connections.
What happes as motorhomes age is that the 120VAC connections get loose & heat up. I founs ONE connection in my Xfer switch panel that was loose and it looked like it had overheated at one time.
Itghtened up & all is well.
38,708 PostsLatest Activity: Mar 06, 2025
