- kekoaExplorerford chassis, 31 ft
- Golden_HVACExplorerYou would need to take it to a scale.
You have no idea what the prior owners might have installed in the RV, or taken out furniture that might have been included in the original build specs. They might have changed from stock single or dual battery to 4 or from a factory 4 battery set up to something different.
Some manufactures installed a lot more stuff, and barely had any cargo weight capacity left over once the fresh water tank was full. Others had a more reasonable cargo rating.
And best reason I can not give you the UVW of the Allegro is you did not give a model number, length, GM or Ford chassis, diesel freightliner, Spartan or Gillig bus chassis.
Fred.
38,769 PostsLatest Activity: Mar 31, 2026
