Av8rkirk's avatar
Av8rkirk
1994 georgieboy cruise air
I have a 1994 Georgie Boy Cruise air 34-foot V8 ford. I cannot locate the reservoir or tank for the hydraulic levelers does anybody know where it is located on this vehicle? Any help would be greatly appreciated as I cannot get the Jacks to extend.
Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★" located at the top of this forum?
    "Forum Posting Help and Support is reserved for questions related to forum posting, signature and photo testing, or reporting member account issues. Please avoid using Forum Posting Help and Support for RV related questions, as doing so can delay responses to your thread. Instead, post in the RV Forum which corresponds to the subject of your topic. Thank-you!"
  • Av8rkirk,
    As was stated above, try following the hydraulic hoses from a jack to the pump/reservoir.
    Our GBM is 10 years newer than yours, but on ours, each jack has it's own pump & reservoir. Perhaps yours is the same?
    And if you don't already know, always check & fill fluid level(s) with the jacks retracted.
    It might be helpful if you could post the manufacturer and model of the hydraulic jacks on your rig.
    Good Luck,
    ~Rick
