robatthelake wrote:
His Generator Does Start! So that means that there is plenty of usable Gas! Seafoam will certainly help ,in any event!
You are correct, I misread the generator post.
All of the suggestions are good except it is Not that easy to cut a Hole in the right spot . Better to drop the Tank.
robatthelake wrote:
One must presume that the Mechanic has done due diligence ,but there are other components that can cause the Fuel Pump to stop running.
I would never assume this. Only real way to tell if fuel is being delivered is with a gauge. If you want to do a shade mechanic trick because of a lack of that tool then a couple of squirts of starter fluid and/or carb cleaner into the air intake to see if it starts, then a slow intermediate spray of carb cleaner to keep it running would tell you if it's fuel related. Would love to know how pulling a relay can do all of this?
