- navegatorExplorerDo not forget to check the switch on the brake pedal, it has to be closed making contact this is what turns the cruise control off when you step on the brake, it has an adjustment nut.
navegator - bartrakExplorerI drove the rv again today and the ABS light came on but when I would stop and turn the engine off the light would go off but would come back on when I restarted . Does that affect the cruise control ? I am in process of trying to see why the light comes on, I suspect a sensor somewhere ?
- tiogaearl31ExplorerHad the same problem. All fuses good. Turned out to be clock switch. Ford repair shop indicated that this was a common problem.
- bartrakExplorerI checked them with an ohm meter and all showed a circuit.
- OFDPOSExplorerYour talking about a 21-22 year old MH with 6100 on the OD ... So do the simple things first... Are there more than one fuse panel too in it ??
As for checking the fuses , you said all were good . Question how did you check them ? If just visually looked at them and didn't see any blown ? Pull each individual fuse and reinsert it. I had come across a few where the customer had said the fuses looked good . Then only to find that yes the fuse was good and not blown , but the contacts were corroded enough to cause the open circuit so to say!
I've had on an occasion to actually take a bit of emery cloth and clean the fuse holder contacts from the corrosion build up then reinsert the fuses..
Just a thought ...
Kinda like when the TV remote doesn't work you take the cover off the back and roll the batteries and then it works fine ... - bartrakExplorerThanks all
I will run the test and let you know what I find. Right now I am trying to reseal everything so it want leak. Lot of places have dried out from where it has sat for most of the time. - ConniePExplorerWe had a problem with our Ford also and it turned out to be the clock spring. My husband ordered one online and changed it and the problem was fixed. Hope this helps.
- AvaExplorerHi, look up thorssell. net. It has all the info needed for self testing. There is a wiring and parts diagram and a troubleshoot list. You don't have to pull a steering wheel to check the clock spring. There are checks at the cruise control amp that will let you know if all the switches work. Good luck
- bartrakExplorerFound fuse panel under dash and checked all fuses, all good. Checked pressure switch on master cylinder, it is ok. I have a scanner that I am going to hook up to see if it throwing a code.
- bartrakExplorerI might also add this rv has been sitting for quite a while. It belonged to to an older man that died and only has 6100 mile on it, that is one of the reason I bought it. It had only been on short trips less than 200 miles. Every thing else works as supposed too.
38,780 PostsLatest Activity: Aug 05, 2026
