Does anyone know where the hot water tank shut off is on this Class C RV 1995 Minne Winne is there one ? I cannot not find it or do I just blow out the water for winterizing -------- Thanks
The bypass is usually located behind the water heater. You may have to remove a drawer or something to access.
You should have a drain on the outside to drain the HW tank and yes you can just drain the HW tank replace plug and use 40-50 lbs air pressure to blow out all the lines. Remember the water filter if installed. Then remove the HW plug one more time to get rid of any accumulated water. Theoretically the removal of the plug is not necessary but you will sleep easier
