dougrainer
Mar 28, 2016Nomad
OK, You do NOT have a Heat Pump. You have a FURNACE. The directions you followed were the CYA instructions from the furnace maker. You do not have to turn the LP OFF. Leave it on. Then just set the Tstat to Heat(furnace) and the temp to what you want it to heat too. IF it does NOT light, you must repeat 5 or 6 times to purge any air in the LP line. A 1995 Furnace will NOT have a tri start Ignition module un less it was updated in the past 15 years. Current Furnaces have what is called a Tri start module. It will attempt to light 3 times and if it fails the furnace shuts down. Then you repeat the process. Make sure other LP appliances are operating also. Doug
