MrWizard's avatar
MrWizard
Moderator
May 26, 2019
1996 Ford F53 fuel line quick connects, what size ?
the fuel filter in mounted on the inside of the drivers side frame rail uses quick connect fittings
i want to add an inline fuel pump at the output side of the filter to boost fuel pressure to the engine EFI system (yes its low)
i don't want to cut any fuel lines
i want to couple the new pump into the system
if i can find a pump with the correct male ends
One piece of new looped fuel hose with female quick connects
will couple it all together
additional wiring from the fuel relay is of needed
