Gjac
Apr 03, 2016Explorer III
RLS7201 wrote:Your right my 1996 does not have the rail.Gjac wrote:ashlatz wrote:You said in your above post that you had throttle body injection(TBI). Chevy switched to direct fuel injection in 1996. But you could have an older chassis with a TBI which will have lower fuel pressure. If you remove the air cleaner and you see a two fuel jets and see gas squirting out off each jet when you step on the gas you have a TBI. Just something too make sure off before you drop the tank.
Ok performed test on rail . It is reading 30psi . When we shut off it did leak down 2psi in about 2 minutes ?
The OP got it right. Note he said he performed the test on the "RAIL".
Richard
