fx2tom's avatar
fx2tom
Used Daymon Daybreak
Currently thinking about buying a used Class A for cash and getting rid of the truck and trailer payments.
I am looking at a 1998 Daymon Daybreak 3270 with the Ford 460 with about 40k miles.
Downside is that the coach only has one 15k AC unit, will this be sufficient? I know my 15k BTU unit struggles with my 36 ft trailer (but it has 3 slides vs the 1 slide in the motorhome).
Unit has all new tires and looks like it has been well maintained.
Question is - other than the roof what items do I need to look closer at? Anything specific to the Damon that I should be aware of?
Thanks!
  • I have 2-13,500 BTU A/C units in the Sahara and we rarely use the back one. I usually run the front one and use a fan to blow cool air into the bedroom at night. Then again, we never go to the desert, but we've been in 90° weather and one A/C seemed to keep up.
  • Watt's law is power equals volts times current. Therefore, 5000 watts divided by 120 volts equals over 40 amps from generator. The system is probably set up as 30 amp though.
  • fx2tom wrote:
    Sounds like I need to look further at the coach and see if, maybe, I can tell if it is prewired for the 2nd AC unit. It has a 5kw Onan gen, would that likely indicate a 50 AMP set up? Or, am I wrong on that?
    I check my neighbor and his 5000 watt is only 25 amps. My other neighbor has a 5500 and his is 30 amps. Maybe Doug will ring in. He will know for sure.
  • I have an 06 Daybreak. One thing to look for, if it has hydraulic jacks is to check the lines running from the pump to the jacks. Make sure they are strapped away from the engine. They had a recall on this for mine and it could be a major fire issue.
    I see your in Ca. If you travel in central Ca it could get warm in the summer. I don't get much help from the dash a/c.
    I have the 5kw onan and it has 50 amp.
  • I would bet on a 30 amp set up. Even at 37ft, we rarely need more than one ac unit but at times we do. When we do need the second one, the 30 amp is sufficient.
  • Sounds like I need to look further at the coach and see if, maybe, I can tell if it is prewired for the 2nd AC unit. It has a 5kw Onan gen, would that likely indicate a 50 AMP set up? Or, am I wrong on that?
  • make sure frig and furnace work. thats only couple thousand miles a year might be a real goody.
  • I would say you will need two. Our neighbor has a 32 and only one and his is always hot when we travel together.
