polar76
Oct 15, 2018Explorer
Ivylog thanks for your comments
You may be confused because the quote you posted
"And reasonably low boost at cruising speed no uphill grades" was from Brett not me.
What I said was :
"On a test drive it did not show much boost till the RPMs got up to around 1600. and then was only around 12psi
Later I posted , "I am mainly concerned at the lower rpms as it doesn't show any boost while cruising on flat ground at approx 1100 rpm."
I do get good mileage from 8 to 9 mpg towing (only 32' long coach)
had it since 2010 and always wondered about the puffs of smoke when stepping on it.
And of course like many, I'm always looking for more power... :)
What I said was :
38,774 PostsLatest Activity: Apr 26, 2026
