- shastagaryExplorerif you have trouble tracking down how things are wired one of these Wire Trackers works good and you can make new friends by having one. i have helped people in there rv's and boats find out wiring they have been trying to figure out for a long time. it works by injecting a radio frequency signal into the wire that you track with the signal tracer. wire tracker
- SparksvonrouExplorerThank you everyone for the helpful posts. I will start digging up individual info as I can and tracing things as best possible. It's for the solar addition I am doing myself. This will be the second rig we did solar and a new inverter and solar controllers on. There will be an additional mod adding our Ham Radio to the rig. At least the plumbing diagram and engine/start diagram seems pretty good.
- ksg5000Explorer III wouldn't get too concerned. I asked Fleetwood for the location of water pump relay and discovered that it could have been in one of 5 location's. Given the age of your rig you may discover your rig didn't come with an inverter but just a converter and any inverter was put in by another owner. As someone else indicated - the mfg of the particular device is better source for wiring on any specific product.
- MrWizardModeratorsafari and winniebago, have wiring diagrams of what connects to what
but they are among the few exceptions
but i have never seen a diagram for ANY RV that shows where wiring or plumbing is routed ( IDK maybe Prevost does )
you can find out what is on the same circuits, simply by turning them off and on
both the DC circuits, and 110v circuits
but finding the junction points/boxes ? is a matter of logic and searching (that info is NOT normally available)
Most RV mfg do not have published wiring diagrams - shastagaryExplorerstart writing down the brands and model numbers of the separate components like the converter,inverter,appliances etc. and use google to look up the brands and model numbers. you can at download the manual installation manuals and electrical diagrams for individual components that can show what the connections are on each of them to help you diagnose problems or at least what they are for.
- ScottGNomadRare that any brand has them. RV's are simply wired as needed, much like a house is.
- darsben1ExplorerThey did not have one for mine either. Are you having a problem or just getting your resources in line like I did when I got mine.
38,780 PostsLatest Activity: Aug 05, 2026
