GrampaKoot's avatar
GrampaKoot
1998 Allegro Bus Kwikee steps
Steps will not close. Door magnetic switch is functioning. Light under steps remains on always. When measuring voltage at the magnetic switch I get 0 volts when door is open and 0.6 volts when door is closed.
Should I not be getting 12 volts at switch?
  • Sounds like you have lost one of the power sources.
    Verify that the two fuses are good.
    verify that the two grounds are good.
