bradr1911's avatar
bradr1911
1998 Class C Super Duty
My wife and I are looking at purchasing a 1998 Santara 30ft Coachman Super Duty. It looks to be in good shape with 60000+ miles. Not sure if the price is reasonable though at $10,000.00. This will be our first RV, used with light travel to begin with. Looking for opinions or any experience with this model. Thanks
  • See if you can post some pictures of it. I often think people should do that here if they want to know if it's a good deal or not. :)
  • Consider having the rig pressure tested (cost about $100 or so)- that should identify all the potential sources of leak. Also - determine the age of the tires - RV tires often deteriorate from the inside/out so exterior looks don't always tell you the whole story. Also - rig hasn't been used much so make sure the chassis air conditioning system works (like your car if it's not used the seals dry out).
  • DrewE's avatar
    DrewE
    Explorer III
    You know the prices in your area better than most of us would. Around here, $10K would be a good price and a quick sale if it's in good, clean, solid shape.
    I have a '98 Coachmen Santara 315QB on the same E-SuperDuty chassis, and I've generally been happy with it so far. Do check carefully for water damage (which is fortunately less likely when it's been stored indoors) and inspect all the caulking and seams, particularly around the roof and cabover structure, and touch up or redo any that are questionable. Also check the date codes on the tires; if they're over about seven years old, they should be replaced or at the least inspected by a qualified person (which generally involves unmounting them and checking the insides as well as the outsides). It cost me about $1000 to replace six tires at a local tire shop, keeping one of the old ones for the spare.
    While obviously built to a price point, with cabinetry that isn't fancy and occasional minor fit and finish imperfections and so forth, I've found the design of mine to be pretty well thought through--with reasonable access provided to systems and valves and stuff--and the electrical and plumbing and mechanical systems constructed and installed in a satisfactorily workmanlike manner.
    (For what it's worth, the E-SuperDuty was renamed to be the E-450 in later years, and often parts store databases and so forth only have the latter designation listed.)
  • The price does concern me. NADA shows between $6k - $7k. He has all maintenance records and it appears to be well taken care of, said also stored in a climate controlled shelter when not being used.
    1998 Coachman Santara Motorhome
    ?Add: Priced to sell / $10,000
    ? Only used 1-2 times/year
    Always stored indoors
    ? 30 ft Ford Super Duty 10 Cylinder
    ? 60k miles
    ? Tires low mileage with good tread
    ? Onan generator -- microlite 4000
    ? Refrigerator electric and gas
    ? Hot water heater -- 6 gal
    ? Cruise Control / Tilt steering wheel
    ? Shower / Tub / Toilet
    ? 16 ft awning
    Sleeps 8
    ? Sleeper sofa
    ? Kitchen table/booth turns into bed
    ? Master bed Queen size w/lots of storage (closet each side of bed and above bed)
    Over the cab Full Size bed
    ? New microwave
    Rear Ladder with top storage
  • 10K seems high to me. Things to be concerned about on any RV that old, roof, water leaks, appliances all work or at least recently replaced. That does not count the normal wear and tear on the drive train. Oil and filter changes, transmission service, brakes all need to be checked.
