FIRE_UP
Jun 23, 2012Explorer
OK,
So, at this point, you may or may not have more than one problem. But, the first task on the agenda is to get the fan working. If you hear a click, like a relay, then the system may be working but, the fan may be burnt out or, a wire fallen off of it or ??? It's time to get the volt/ohm meter out or, even a little test light to see where power is and where it isn't when the system is activated.
Once you get the issue with the fan done, you may have good A/C. You won't know 'till the fan situation is remedied. But, if it's a worst case scenario, you could have burnt out fan motor and, leaked out refrigerant. But, take it one step at a time and see where it leads you.
Scott
Scott
38,780 PostsLatest Activity: Nov 24, 2017
