cpeter99's avatar
cpeter99
1998 Holiday Rambler Vacationer? 13k Is it worth it?
Hi All,
I'm brand new to RV life, my wife and I are working on building a house and will be planning to live and travel on the road for the year as the house is being built. Our RV budget is around 13k.
I have found a 1998 Holiday Rambler with 24k miles. It looks to be in good shape, will be traveling to see it tomorrow. It has a 454, I believe it is the 34CG model.
Would this be an okay start RV for the cost. It looks to be in great shape and the price is right, everything else I have seen as of late really doesn't look good in that price range.
I'm looking for thoughts and comments on what I should look for and if the Holiday Ramblers are over all a decent rig.
Thanks
  • The harsh reality is that any RV of that age will most likely will require an expenditure equal to the purchase price in the first year to keep it on the road and fully functional. There are rare exceptions, but considering your inexperience you will not know the difference until it is too late.
    No offence intended, I am only pointing out what seems to be the obvious to any experienced RVer.
    Considering everything involved, my opinion is, you should rent an apartment in close proximity to where the new house is being built and be there every day to watch over the project. Building a home is a monumental project and the ramifications of problems may last for decades.
    I am in envy that you have the resources to proceed with such a plan, but I would not attempt it due to some of the above reasons. The idea to go on the road and tour the country to return to a new and perfect home are just not realistic in my opinion.
    I genuinely hope other members will chime in with a more optimistic outlook. A full “Pre Delivery” inspection of an RV before purchase should take about four hours to check out all the systems and the entire rig from top to bottom. Take a ladder, creeper, flashlight, multimeter, camera, and lunch.
    DO NOT, supply any payment or deposit in advance, that will be the end of your negotiating advantage.
    Best of luck.
  • 1,000 miles a year suggests it sat for extended periods of time which can also be a problem. 2 things: Be sure you have a FULL PDI (Pre Delivery Inspection) list, top to bottom ie underneath. And leave the emotions at home and be prepared to walk.
