bfrein
Jul 26, 2017Explorer
Thank you all for the quick responses.
The shop we stopped at did check the fuel filter. He could blow through it but since he had it off, we just replaced it as well. They mentioned that it may be the fuel pump starting to go. At the time they tested it, the pressure was in range.
Unfortunately the pumps aren't stocked anywhere local so it will take a few days to get in. We will start unpacking
1995brave - I will check the air filter and also have the shop check the vacuum lines.
Thank you
Thank you
