allbrandauto
Jul 26, 2017Explorer
there is a test for the fuel pump even though the pump is still running its called a low amp test you need a mechanic to hook a low amp probe on the wire to the fuel pump your looking at a wave patterm that will tell you if the pump is good or bad you may go on you tube to see this test performed
38,782 PostsLatest Activity: Sep 10, 2026
