rgatijnet1
Jul 27, 2017Explorer III
The P30's did have ignition switch problem which could cause the engine to stall if contact is lost. This was usually a failure caused by excessive heat in the switch from the headlights and eventually the switch would fail to make ignition contact while running but be OK after it was reset. Just a thought.
38,782 PostsLatest Activity: Sep 10, 2026
