tenbear
Mar 12, 2015Explorer
Here is my opinion.
My first choice would be to replace the Magnetek converter with a modern 3/4 stage converter. Lacking that, I would get a battery maintainer such as a Battery Tender or a trickle charger for keeping the battery charged.
In any case, keep a close watch on the battery water level until you find out how long the method you use takes to boil the water away.
If you do use the Magnetek, invest in a multimeter to measure the battery voltage so you know when it is charged. 12.6v after the surface charge has leaked off will indicate the battery is fully charged. Don't trust the idiot lights. 12.1v indicates the battery needs charging.
