jim427
Apr 20, 2019Explorer
1999 Fleetwood Discovery 38 ft. battery relays
Recently I noticed a "buzzing" in the back of the coach when it is parked, on shore power, and both battery relays are in the on position. I finally found it in the battery compartment, and it was the 200 amp. SPST relay mounted on the wall of the compartment. I tapped on it and the noise temporarily went away, but later returned. Then I started the engine, and the 12vdc house lights came on along with the running engine, but then both died. After 3 cycles of this the engine and lights remained on, but that relay is now oscillating on and off when both the battery relay switches inside are turned on. Not knowing what's going on I am leaving both relay switches off until hopefully someone here has an idea what's happening. Is the relay now bad? I see it has a bolt head on top and thought maybe I could open it up and clean the contacts?? Any ideas are appreciated.
