Big_Plummer's avatar
Big_Plummer
1999 Ford F-53 V10 will not start after sitting for a year
Hello Everyone
I have a 1999 Damon class A motorhome on a Ford F-53 V10 chassis that will not start. I tested the start solenoid an found it working and also jumped the solenoid the motorhome started. I found no12v on wire feeding the solenoid from the ignition switch so I replaced the ignition switch, battery and checked all fuses. Still will no start, when turn key to start position there is nothing, every other position works correct. Is there another relay or switch in line with the wire?
