tbr6654's avatar
tbr6654
1999 georgie boy cruise master power loss
I have a 1999 cruise master with a Cummins ISB and 6 speed trans. On a recent trip it suddenly loss power and would only go about 40 mph up a grade. So I changed fuel filter and separator and did find debris in separator. It did not show any improvement. Next step was to drain fuel tank, change filters and filled filter canister with injector cleaner. Still no luck engine doe's not smoke and seems to run smooth but no power.
Thank You for any advice
Greg
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
    Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread. Instead, select the Sub-Forum which corresponds to the subject of your topic. Thank-you!
Moved from FORUM POSTING HELP AND SUPPORT
