EastTexasFoster's avatar
Sep 22, 2017
1999 Southwind 35s 110v Problem Solved, Circuit Breaker Bad
Just wanted to post this experience to hopefully help the next person who runs into the same problem.
Noticed one day that the little 110v fan my wife had turned on was stopped. I thought maybe it had just died from old age, but she insisted that it was still good. It was plugged in on the kitchen under-cabinet GFCI outlet. I checked all the GFCI outlets, none were tripped. The breaker for that circuit wasn't tripped, either. We were traveling, so I resolved to investigate it after we got home. Later on, running on generator, we stopped and turned on the coffeepot plugged in below the dining table. It came on, then died. This time, the circuit breaker was tripped. Tried to reset it, same result, tripped breaker. It was then that I realized the breaker seemed to move around a bit when pressure was applied, as if it wasn't properly mounted inside the box.
I shut off the generator and undid the metal cover and pulled that circuit breaker out. I noticed that there was broken plastic around the brass groove where it pushes onto the corresponding brass prong that carries the current. It wasn't terribly obvious, but there was some plastic missing.
Looking more closely, I saw that the metal groove was dark and had a rough surface. Looking at the metal prong that fits inside of it, I again saw dark spots and some pitting.
What I surmised had happened is that the breaker had been vibrating and bounced around for years until the connection was less than ideal; this caused arcing and heat, causing the plastic to break away; then, the problem got worse because the missing plastic allowed more motion. The end result was that the pitted connections weren't conducting electricity as they should, instead generating heat and kicking the breaker. Worst case could have been damage to anything plugged into that circuit, or even a fire, but thankfully it didn't get that far. A $20 bill for a new circuit breaker and 5 minutes to swap it out solved the problem.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Had the same thing happen 2.5 times myself but it was the Campground's breaker, not mine
    1: Park the 30 amp breaker, NOT the standard Square D (Different make) when the maintenance man opened the box. ... Scary I can tell you.
    Another park (Standard Square D type breakers) the 50's were tripping at around 20.. THey were so hot that the Electrician got gloves to pull 'em and even after he got it all back together they were still too hot for me to handle comfortably.
    The half.. I was told the site had bad power.. Pressed on the breaker and re-seated it. had good power for 2 weeks I was there.
  • DrewE's avatar
    DrewE
    Explorer III
    Good catch! Likely part of the reason the breaker popped under less than full load is the heat from the arcing at the bus bar causing the thermal part of the breaker to warm up prematurely.
    If it's possible, I would suggest moving the breaker to a different (unused) slot in the breaker box and leaving the spot where it was previously unused. The scorching on the bus bar will not do anything good for contact with the new replacement breaker.
    Frankly, if the breaker can't be relocated, I would be tempted to replace the bus bar if reasonably possible.
