travisadams11's avatar
May 28, 2014
1999 ssouthwind not starting
I have a 1999 southwind with a 454 was starting great running great took the starting battery out put back in a couple days later now I have no power to the dash horn won't turn over anyone with any ideas and also the battery disconect an over the door one of them is only working
  • Sounds like the starting battery is dead or not connected correctly. Recheck your new connections.
    You should have a switch on the dash that temporarily connects the house batteries to the starting battery to get the engine started. If you do, engage it, start the engine then let it go.
    If that works to start you can let it charge for a while try using it again. But, if you have totally discharged the battery it may be toast.
