drakethib's avatar
drakethib
2 Items I need help on for a 2006 Fleetwood Bounder
Workhorse Chasis
1. Is there a fuse for the potable water pump? If so where is it located? ( My water pump isnt working and trying to back track)
2. I have a "switch" on my bounder whereas you press it and it flashes your headlights ( i.e. in case someone is trying to pass you and you want to let them know al clear to move back in the lane). My doesn't work and I think it may be a fuse as well, but don't know where the fuse panel may be.
Appreciate any help someone may offer.
Thanks
  • Looked back at your post, you have a Workhorse Chassis so I didn't help you much with the ICC Flasher fuse. Sorry about that
  • I have a Fleetwood coach and my pump comes out of the 12 volt house panel. Mine is in the front bathroom, yours could be just about anywhere. The box they are mounted in is about 6" square and they are usally close to the 120 volt panel.
    The other fuse you are looking for is under the dash, left of the stearing column, if you have a ford. It called the ICC Flasher. If working corectly it will flash all the running lights at the same time.
  • Corkey05 wrote:
    Here's the Manual for your coach.
    2006 Bounder Owners Manual
    Page 07-2 tells you a little about where to look for the water pump fuse. The index in the front of the manual tells you where the fuse panels are located.
    Good luck :)
    yeah, the manual is not real descriptive on the exact location.
    Appreciate the help !
  • past-MIdirector wrote:
    The switch flashers your running lights only!
    Hmm.
    I need to see if these blink when I hit the switch,
  • RLS7201 wrote:
    The water pump fuse is next to the water pump. Your switches actually control a monoplexer that controls the negative side of the water pump circuit.
    Can't be of help with your other question.
    Richard
    95 Bounder F53
    Thanks Richard
    Right now if I switch my water pump on, the orange light is illuminated but I do not hear the pump trying to pump, hoping the issue is just a fuse, looked today and my water pump is kind of hidden behind my fresh water tank which will require a little time to get to.
  • The water pump fuse is next to the water pump. Your switches actually control a monoplexer that controls the negative side of the water pump circuit.
    Richard
    95 Bounder F53
  • Here's the Manual for your coach.
    Good luck :)
