- OhhWellExplorer
Romer1 wrote:
Captain_Happy wrote:
1998
Thanks.
Assume they are metric as opposed to 8R?
Any comments on the V10??
1998 was a transition year for the F53. Ford technically made no 1998 F53s so 1998 coaches are either on a left over 1997 with the 460 and 16' wheels or the 1999 with the V10 and 19.5" wheels. As someone mentioned, the possibility of getting a 2000 coach on the 1997 chassis is so remote as to be statistically impossible but I guess you never know.
Comments on the V10? It's a great engine. I think the 2000 was still a 2 valve but had improvements to the breathing bringing it up to 305 HP. Anyone know if they went to 6 thread spark plug sockets by 2000 or was it still the 3 thread that could blow a plug if you weren't VERY careful about the torque when changing them?
There is an issue with the factory exhaust manifold that I believe went all the way up to 2011. The problems were twofold. One was that the studs that hold the manifolds to the engine were prone to corrosion and failure, the other was that the paper gasket allowed the manifold to heat at a different rate than the engine block and crack.
To solve the bolt problem is about $40 in parts from Ebay or amazon and a bit of labor depending on how many factory studs break off in the block and have to be tapped/drilled out. The fix for the gasket issue is to use no gasket if the engine is new or a copper one if not (or install some nice headers like the PO of my coach did :B).
Other than that, it is a 200,000+ mile engine easily with regular maintenance. - LVJ58ExplorerTire size 245/70R19.5 anyway that's the tire size on our 2000 Residency with the Ford f53 chassis...
- Bruce_BrownModeratorIt won't be on a '98 chassis - not a chance. Way too many of those built to be on the old V8 chassis.
While generally considered a quality built unit, some had issues. In that time frame Winnie had issues with bad fiberglass roofs and delamination. Be sure to look very closely for signs of water leaks in the ceiling and delamination in the sidewalls. If either are going on bad things happen. Some were even known to blow off (1998-2000, with most being earlier rather than later). :E
Here are pictures of a 2001 we worked on last year;
Here is an older post on the subject - for those who say it can't happen with a fiberglass roof; :W
Old Post with Examples - BumpyroadExplorer
Romer1 wrote:
Bumpyroad wrote:
just be sure it is on the New Ford chassis with 19 inch rims and V10.
bumpy
When was the change to 19?
be sure that it is the new chassis with 19 inch rims and V10. they could have put a 2000 unit on an older chassis. DO not go by the year of the motorhome.
bumpy - Romer1Explorer
1998
Thanks.
Any comments on the V10?? - Captain_HappyExplorer1998
- Romer1Explorer
bumpy
When was the change to 19? - BumpyroadExplorerjust be sure it is on the New Ford chassis with 19 inch rims and V10.
bumpy
38,778 PostsLatest Activity: Jun 10, 2026
