gfs1943
Apr 15, 2016Explorer
al hillman wrote:
The code on the generator blinks 4 times pause and 6 times. Think that is code 46 which is low battery. Where is the generator battery located? The generator is a Conan quiet 7500 diesel. The generator does click like low voltage. Is the battery in the front behind some cover or is it in the back where the 2 12v chassis batteries and 2 6volt house batteries are??
On most motorhomes, there is not a generator battery. The generator will use house batteries, or the chassis batteries to start. On my Itasca, it's the house battery, but I can't say about your HR product. Also, my coach uses the chassis batteries to operate the slides and jacks. If yours is the same, then you probably have two unrelated problems. I suggest you start by checking the house battery voltage. Also, if you have a boost switch that connects the house and chassis battery systems, try holding it on while you're trying to start the generator.
When you get it figured out, please let us know what was the problem and how you fixed it. Best of luck!
38,763 PostsLatest Activity: Dec 05, 2025
