TTitans1's avatar
TTitans1
2000 Itasca Horizon 34BD Power Inverter
Need a little help here once again. We own a 2000 Itasca Horizon 34BD Class A motorhome which we live in most of the year. It has been parked and connected to a 20 Amp 110V outlet for 2 years and was working fine until I asked an electrician to wire up a 30 amp plug so that I could possibly run the A/C system this year. He came out and wired a 30 amp plug but he connected it to 220V instead and I believe he fried the Shoreline power converter box. After he realized what he had done he and a mobile RV mechanic bypassed the power converter box so that we would at least have AC power and not have to stay in a motel while waiting on a new box which I ordered. My confusion is that when he initially did this I had no AC power so I was looking at my power management panel in the RV and I did not see any of the lights on for the battery charging system on the bottom of the panel so I pressed the POWER INVERTER button and immediately had AC power and the lights for the battery charging system on the panel lit up. I do not remember having to press this switch after losing AC power (from blowing the 20 amp breaker and then resetting it ). Is this an indication that he may also have fried the power inverter? The RV guy seems to think so but I think that it shows that the inverter is working. Also since he bypassed the inverter I can't really test it until we get the new Shoreline switch in, Can someone clarify this for me? Also don't know if this had anything to do with it or not but now my furnace does not work either.
Thanks in advance
  • TTitans1......I read and reread your post several times and it didn't make sense. It wasn't until I started to type a response it dawned on me what you're talking about. You're calling your Shoreline TRANSFER SWITCH a power converter. The terminology you used threw me off.
    What you had happen isn't unusual. Many RV plugs are wired with 220volt by electricians who aren't familiar with RV wiring. The good news is....it sounds like they only ruined your transfer switch and didn't fry anything past that.
    You said when you have tripped a breaker in the past, you didn't recall the inverter taking over. Inverters are usually turned on and off as needed. When you turned yours on and everything had power, that was the indication that nothing suffered damage inside the coach.
