blknomad's avatar
blknomad
2000 Itasca sunflyer
A friend has purchased his first RV and he is very excited. I have had a class a for 9 years so he asks me a lot of questions. Does this ford chassis have the same sway bars as the f53? What does it need to drive better? What suggestions would you have to upgrade the tv ? Any other helpful hints toward this model would help.
Thanks
  • We had a 1998 Sunflyer and it was on the F53 chassis. The TV was replaced with a 32" LED Smart TV attached to an arm on a wood panel across the TV console above the cockpit. We did replace the old video distribution but kept the Winegard OTA antenna. All in all, it was a good unit which had the major drawback of the kitchen being in the slide, so some of the plumbing developed leaks as it was used more and the slides went in and out. All very easily fixable, but a PITA.
    It seemed to have the standard Ford sway bars, it handled just like other F53 chassis.
  • haven't seen it yet just wanted to be able to help when I go visit.
  • Check the roof to wall seal. Bad things happen when that goes bad.
