RLMiller's avatar
RLMiller
2000 Safari Intermittent Beeping
Gentlemen,
Intermittently a loud beep can be heard from the vicinity of the monitor and inverter management panel. There are no indicator lights, or other indication as to why the loud beeps, lasting up to several minutes. Has anyone experienced this problem, and if so, how did you fix it?
Thank yhou
  • Two Jayhawks wrote:
    OnaQuest wrote:
    Two Jayhawks wrote:
    Below the management panel is the CO2 detector could that be the source?
    CO2 ?. I don't think so. You probably meant CO detector, but even that is wrong. It is a propane (LPG) leak detector.
    Actually mine was a LP and CO detector.
    My point was; it's not a CO2 detector, and neither is the OP's a combo detector. Sorry!
    Ours is like that (CO+LP), as well. It's important to have both. If you don't, it might be good to upgrade.
  • Some inverters beep to signal low voltage, high temp and/or overload.
