steveownby
Nov 09, 2013Explorer
Here is the brochure on the Knight:
http://www.monacocoach.com/StaticFiles/monaco/brochures/2001/01Knight.pdf
I'm guessing you won't be happy. If you go with the old rule of thumb of 1 hp per 100 pounds then you are on the line with coach only. Add your trailer & cargo and you will be below that benchmark. Also that coach is equipped with a 4 speed Allison instead of the 6 speed. The hitch is also rated at 5k or below.
Bottom line is it will be slow off the line and up grade.
That year coach had an option for a Cummins ISC which would perform substantially better.
38,780 PostsLatest Activity: Aug 05, 2026
