faucet1
Oct 09, 2018Explorer
Just saw your reply. Thanks for the suggestion. There are three Relays side by side on that Board. The Accessory and Ignition Relays were getting very hot and was/is shutting power off to the Ignition. I jumped the Ignition relay and was able to try and get home. But, it got dark and I had to turn on the Headlights. Then, that Relay started getting very hot, and finally shut the power off to the Ignition. So....I'm not sure where the problem originates. I am going to start by replacing the Ignition Switch, since that Relay originally was getting very hot, and replace the Headlight Switch since the Dash Lights are almost non-existent and that Relay got hot once I switched the headlights on. Beyond that...I'm open to suggestion.
