Sam_Spade
Dec 10, 2018Explorer
Are the levelers REALLY air operated ?
Kind of hard to raise that much weight with air.
I would think hydraulic.
Has any one LOOKED to see if the jacks are really down ?
Sounds to me like the indication is that you are telling it to raise the jacks when they are ALREADY UP.
Then.....the leveling system should have a manual mode.
Raise the levelers, which probably is NOT the "dump air" function, and then start over in the manual mode. Might have to have the engine running to do this.
If mine is reasonably level to start with, I just run the jacks down until they make firm contact with the ground for stability and not for leveling really. If his unit doesn't tend to sway when people walk around inside, he might not need the levelers at all sometimes.
