devildog1971
Apr 01, 2018Explorer II
2002 monaco setup charging system
Thanks everyone without your help I would have been overwhelmed long ago. I have 4 six volt batteries duracell bought at batteries plus 255amp hrs at 20 hour rate how do you set up the charging system xantrex power sharing I have the diesel generator 50amp a book would be nice but I do not have those pages I found some pages in the bay compartment when I bought it and many were wet and ruined. The batteries were bought new in january 18 I do not want anything else to go wrong at least that I can prevent so a simple explanation would help because I have dealt with so many problems on this maiden trip and being disabled does not help for those of you that have kept up I pulled myself onto the roof and the awning problem is solved until I get home it is pinched in between the slide so if the slide is not used no unfurling in the wind this I would like to get right. Is the 1020 amp hrs divided in half since they are 6 volts? then how do you set up the charging system thanks in advance Semper Fi
