- Hunter3142004Explorer
blownstang01 wrote:
Look for a access panel above the LP tank.
THANK YOU THANK YOU, You are correct a false panel above the LPG tank with all the great silicone and 20 plus screws to remove // and there it is in all here leaking glory. Thank you again for the insight, it is greatly appreciated. - msmith1199Explorer IIIt should be close to your water tank. Fill the tank and turn the water on inside and you should be able to hear the pump and find it.
- MountainAir05Explorer IIand if not there, open a faucet and follow the sound, should not take but a few minutes to find it.
- blownstang01ExplorerLook for a access panel above the LP tank.
