JaneNLee's avatar
JaneNLee
2002 Winnebago Minnie w/ slide
Hi
Need to get some opinions from any one who had a 2002 Minnie Winnie 24ft w/ slide and a V10 FORD with 61,000 miles.
I know when the V 10 came out, it had some problems, but now has everything in check.
Anyone own one or have a V 10 2002 vintage.
Thanks for your help.
Happy Rving
Jane and Lee
  • I have a 2003 Winnebago Itasca 31' with 52,000 miles, V-10 and it has had zero problems. All that I have ever done is changed the engine oil and filter,(motorcraft) greased the steering parts and changed the air filter. No other fluids have needed adding. It has towed a Ford Explorer most of those miles.
  • I have a Minnie Winnie 29B 2003 but on a 2002 E450 chassis. The V10 seems to hold up.
    The issue I have run across after buying it was the previous owner let the MH sit it only had 37000 miles when I bought it. I have had to service EVERYTHING that needed servicing. Check all service records .
    Minnie's are great motor homes.
  • Ford E450 seems to be very reliable . Look at the milage listed on these ads
    http://www.rockanddirt.com/trucks-for-sale/FORD/E450/invnum=10237353
    http://www.rockanddirt.com/trucks-for-sale/FORD/E450/invnum=10129720
  • We bought a 2003 Minnie Winnie 24F (Ford E450) last week. It has 85,000 miles. New tires, Onan generator (1300 hours), Clean and is in good condition for it's age . All for $13,500. We have been using it this weekend and we are very happy with it.
  • We bought our 2003 Minnie 324F with one slide new (see my sig below). It now has 83,000 miles on it and has never been in the shop. All scheduled maintenance done by me. No issues with spark plugs or anything else on the engine.
  • Thank you for the detailed explanation.
    I printed it out and plan on using
    Happy RVing
    J&L
  • j-d's avatar
    j-d
    Explorer II
    Your version of the V10 story is pretty much true but incomplete. There are also misconceptions. Let me try to bottom-line it for you.
    1. When V10 came out, Ford "E" Series (vans, Class C's) and "F" Series (pickups and Class A's) got the same 275-HP Two-Valve (the classic One Intake Valve/One Exhaust Valve design). These engines had only a few threads holding the spark plugs in their aluminum heads, and a many had failures. This was 1997-98-and-99 Chassis years.
    2. Come Chassis Year 2000, Ford re-designed the heads, labeled them "PI" for Performance Improved, went to 305-HP, and this included more plug threads. Problem now, some of the heads made at some of the component supplier plants had the threads and plug seating surfaces misaligned. This caused a few more failures. From what I understand, it took till Chassis Year 2004 for every head installed on a V10 to have correct spark plug alignment.
    3. In the early 2000's, Ford upgraded the V10's going into F-Series (pickups and Class A chassis) to a Three-Valve 362-HP design. That left little room for spark plug holes so Ford came up with for very different spark plugs and a whole new series of problems came up. If you're looking at a Class C, NONE are affected by the latest set of issues because NO E-SERIES EVER GOT A THREE VALVE ENGINE!!! Don't let people freak you out over those problems.
    If your Chassis Year (look at Ford's label in the door jamb and Owner's Manual in the Console) is 2000 or newer, I believe you are at little to no risk. As proof I offer my Signature. I knew about the spark plug issue, researched it, and decided owning one was a safe bet.
    Hope this helps.
  • Thank You for your input on the V 10. Do you also have a Minnie? Happy RVing
    Jane and Lee
  • I have a 2000 with the V10.
    40,000 miles no problems.
    The V10 is the Ford gas workhorse.
    From all I read the early spark plug problem was
    corrected long ago.
