MountainAir05
Jul 19, 2013Explorer II
as stated low Freon. When the compressor comes on when testing does it cool. If you have a gauge set, have you check the pressure. Also if the low pressure switch is bad it won't come on either. You can unplug the wire from switch and jump it. If compressor comes on you found it. If wiring , its going to take a while to check it out. Is this a Evans Tempcon system.
38,782 PostsLatest Activity: Sep 21, 2026
