stoshb
Jul 19, 2013Explorer
I watched a technician put hoses on both the low and high pressure connectors on the AC system. Don't remember exact numbers, but both values were appropriate for a full system, without the compressor running. This tech then shorted the low pressure switch and nothing happened. His verdict was to replace the compressor, but because of its location, did not want to have any to do any more work.
Second technician, did same test, though I did not witness the pressure checks, and then he went further and tried to force the compressor to come on. I am not sure what wires he used to make this happen, but were related to the engine electronics. In his testing he kept thinking that there was something wrong with either the computer or the switch, but parts issues stopped him from going further.
Third technician also discovered issue with one cylinder misfiring and wanted to blame the computer. However, after more investigation found a bad wire, replaced it and the misfire went away. He now thinks the computer is OK, and, at over $700, really no one is prepared to throw away the computer until we are positive. He is leaning toward the switch being the issue.
I don't have physical possession of the unit right now, but should get it back tomorrow. Love the suggestion to just test it with a voltmeter and will do that first thing when I get it back. While I am hearing trained people point to the switch, I just think there is something else there near the switch that is causing the problem. Just wondering what else might be there.
Had not heard the name of of the company that actually made the other AC parts. Mistakenly thought that they were GM. But then no one company makes all the parts on anything. Had already figured out some of the parts were sold by Fleetwood so they wouldn't be GM parts.
38,782 PostsLatest Activity: Sep 21, 2026
