CG Dawson wrote:
Battery is known good, there is no power to the ignition sw module, it has started a couple of times intermittently, so don't suspect fusible link at this point. There is power to the BCC & the steps. Suspect a solenoid somewhere between the BCC and the ignition module.
Not sure if this will be the same as your 2003 F53, but I had the same type of issue on my 2000 F53. There's a solenoid on the radiator bracket, top passenger side. This is the ignition solenoid that starts the engine. I had an intermitting problem with starting the MH and replaced this part. Before you replace try cleaning all connections. Make sure you disconnect your battery prior to playing around. If this doesn't help, try jumping around the solenoid. If this works replace part.
-paul
