Gene_in_NE
Jun 05, 2013Explorer III
girasoledonna - You have gotten your fair share of great advice. I would, however, encourage you to not hand over the final check until you test drive the unit. Take it on a 4 lane with some "semi's" and some wind. There were some complaints on certain units about "white knuckle" driving. I do recall some were able to fix the problem with a change of tires (other than Michelins) and the spacers on the rear wheels. The main reason is "Why does this one have low miles?" That makes it a tad suspect.
The chassis with the 318ci (5.2L) is almost bullet proof and the appliances are readily available.
Best of Luck. Better to take a bus home with your money versus owning something you cannot drive comfortably.
38,782 PostsLatest Activity: Sep 02, 2026
