Frenchman's avatar
Frenchman
2003 Southwind 32V Digital Dash issue
why did my dash quit working. Had to drive 45 miles to home with no dash indications. Anyone experience this problem? my chassis is a Workhorse with a Chevy engine 8.1
  • You can get info on recalls and other stuff for your Workhorse at this website Workhorse.
    A very old recall exists for the instrument cluster will be listed as follows if its been done:
    50402-C, Actia Instrument Cluster, Date
    If your chassis has had it installed you should find it at this site after you register it by vin #.
    Also, you can check out this website irv2 WH forum for lots of info on Workhorse.
  • found a place in Idaho that fix that dash called module masters about 300 dollars
  • Known workhorse issue...the Actia dash fails...call workhorse dealer and hopefully they can use an outstanding recall or the TSB on it to fix it.
