Just purchased a 2004 BT Cruiser. The electrical outlets are not working. I tried to reset the GFI plug but nothing changed. I am having problems identifying which fuse to check to see if that chan...
Main power in from the plug in. That goes to circuit breakers. One breaker will feed your converter. Other breakers will feed 120 volt fridge and GFCI plugs, outside plugs and counter plugs.
Usually breakers are right beside 12 volt fuses, perhaps behind a plastic panel.
