Tucson_Lawrence
May 05, 2013Explorer
The kitchen counter wasn't bad.... but it wasn't good either
Although I keep leaning towards just getting some corian (I have the ability and the tools to shape man made countertops) the cost would be prohibitive to refinish something that although not exactly appealing, wasn't all that bad.
Hard to see in this pic... but it is this color of laminate...
Well... out came the kitchen (and bathroom sinks, oven, and counters...)
and into the shop they went.
Options-
1- replace with corian or other manmade surface.
cost- about $400 if I did the work myself
2- add a piece of laminate sheet on top to change the color.
cost about $170...
but there was a problem. On the edge of the countertop is a PVC edgeband. If I just add more laminate on top, the edgeband wouldn't match up in height... so this wouldn't work...
3-redo laminate and underlay
cost about $220
4- (and what we went with) Rust-Oleum counter transformations kit
cost- $112
http://countertops.rustoleumtransformations.com/
With the money back satisfaction guarantee, I figured I couldn't lose. (and I almost didn't in the end)
First, remove countertops
Second, CLEAN - CLEAN - CLEAN (and then TSP and then clean some more)
Third, Add adhesive and then (with my beautiful assistant's... uh... assistance...) add chips
On a side note, the "removal" process revealed several "interesting" build quality issues such as sink holes that looked like they were cut out by a drunken beaver and cabinets held together by 608 differently lengths of screws with stripped out heads... (sigh..)
Next, sand sand sand... the kit came with a small bit of diamond plate that quickly gave up the ghost so I moved on to my ROS with good dust collection
Finally, add the 2 part epoxy, roll on... let dry and enjoy... almost...
the finish ended up drying to a quite ripply orange peel... sanding only started to break through to the chips and simply wasn't acceptable. I called rustoleum and asked if there was a fix available and the technician was VERY helpful and both offered some alternatives and ALSO very generously offered a full refund on the product as we were not satisfied with their product out-of-the-box
I even told the tech that it was probably usable as-is but would be trying additional materials as recommended to get it up-to-snuff and she still said they would send a refund. I very much appreciated the pleasant and unexpected way in which rustoleum stood up for their 100% satisfaction guarantee even though I was not fishing for a refund.
So after a LOT of additional sanding, $39 additional dollars worth of west-systems 2-part marine epoxy, and some buffing with micromesh, the final results are pretty darned good IMHO.
A new stainless steel sink is on the way too... pics to come of that...but in the meantime, I am quite thrilled with the results of the refinishing job and think it looks much better.
Cost
- Kit $112 (refunded - did not cure properly due to low humidity) great job again rustoleum.
- West-system 2 part epoxy - altered mix for low humidity (thanks John at West Systems for the assistance!) $39
- Sandpaper - $15
- Time- approx 8 hours- not including several days' cure times (would have been less except for the topcoat SNAFU
The bathroom counter was done as well, but I've got a little surprise in store for that one and will add more at another time...
Thanks for reading and please comment/ask any questions you have. I'm enjoying sharing this experience with you,
V/r
Lawrence
(we got the refund check in the mail 3 days after the phone call- great job rust-oleum in backing up your product!) It looks like our drastic lack of humidity (about 3-5%) may have been the culprit. I believe that this product will work "out of the box" quite well in most climates and really like the final result
Options-
cost about $170...
cost about $220
cost- $112
Cost
- Sandpaper - $15
V/r
Lawrence
38,766 PostsLatest Activity: Jan 10, 2026
