John___Angela
Sep 28, 2015Explorer
sportech wrote:
On my 07 Revolution the drains in the water bay can be opened and then you can turn on the pump. Takes about 10 minutes to empty the tank onto the ground. I have a quick connect for a garden hose so that I can get the water away from the coach.
Dave
Yepir. Go to the wet bay, right hand side lower. Hot and cold low point drains. Open the cold and it will drain the tank as well. If you want it to go quick then just turn the pump on. It'll pump it empty in short order.
38,782 PostsLatest Activity: Sep 10, 2026
