D_E_Bishop
Dec 26, 2014Explorer
I did a search for the installation manual for the LCI Coach Steps and the wiring diagram is pretty much the same a Kwikee and about as much use a a Kwikee diagram. Any schematic you get won't necessarily show exactly where connections are made. Following the wire from the line point to the load point is the only sure way of knowing where wires connect to the coach and chassis systems. The fuses may or may not bet in a fuse block, both of mine are inline fuse holders and not to fuse blocks.
38,766 PostsLatest Activity: Jan 10, 2026
