mr_turtle's avatar
mr_turtle
2004 Georgtown 370
Purchased a 2004 Georgetown 370 in April of last year. In a rainstorm 2 weeks ago a leak in the the rear passenger slide (extended) was discovered. In looking for information on slide adjustment, I am having trouble finding info. The bottom of the slide is out more than the top.
In help would be appreciated.
Thanks
Richard
  • almost done roaming - thanks for the insight - will check the slide topper
  • If there is something that is preventing the slide topper from extending when the slide is going out it can cause the slide to tip inward. With the slide tipped inward, the seals are not compressed and any water reaching the top of the slide will run inside the coach.
    Check your slide topper and see if it is hanging up when the slide is extended.
