audman
Oct 31, 2015Explorer
I forgot to mentioned that I had already checked both ends of the wire at the gen and battery and they are clean and tight. I had also checked the ground wire connection from the gen to MH frame.
What you guys are referring to as the 12V switch is what my dealer calls the battery disconnect switch? Mine is located below and to the left of the oven on the kitchen cabinet wall(built in 2003).
I don't if my unit has the high amp circuit breaker in the compartment with the hydraulic pump? I will check for it. I have four breakers in the first compartment back from the driver's door and I checked them.
Thanks for all the replies,
Carl
Carl
38,766 PostsLatest Activity: Jan 10, 2026
