ArchHoagland
Mar 04, 2016Explorer
I have a 2004 Monaco La Palma 36DBD motorhome. I suspect it is like yours as mine actually has a HR insignia on my front cap.
The slides are electrical gear driven, Power Gear brand I think, and I have no idea how to hand crank them.
The only problem I had was with the bedroom slide...a gear broke off the drive motor shaft so it would go in and out in a jerking motion.
Replacing the gear cured the problem. The drive motor assembly is under the bed and enclosed in wood. Simple to get to once you remove the wood cover.
Other than that they are problem free. I haven't seen any posts about these slides not working so I wouldn't worry about them.
Also I don't use the locking bar that they give you to keep the slide from moving out while you are driving down the road. Mine don't creep out and if you put the bar in place and forget to remove it you will wreck the slideout.
I use white lithium grease on the gear tracks about once a year.
For your information the bedroom slide moves about twice as fast as the living room slide.
You need to find out if the transmission fluid has ever been changed on the Allison 1000 transmission if yours is a Workhorse chassis with the 8.1 gas engine.
Make sure the Actia digital readout on the dash is working correctly. It shows what gear you are in and a ton of other stuff. Lot's of problems with the LCD screen so make sure it is legible.
Keep us updated on how your trip goes to pick it up.
38,766 PostsLatest Activity: Jan 10, 2026
