chickendoug
Aug 25, 2015Explorer
chickendoug wrote:.....roblem?....................just back from road test, problem solved, cannot believ it took me 800 miles of off & on lights & buzzers to find out I was a gal. low on coolant!.............bullydogs1 wrote:..............yes on rear radiator, temp does not go up, however I just added 1 gal of 50/50 antifreeze to bring it up to full/cold level. Will road test tomorrow. The other part of my problem is if I run the gen while going down the road this seems to make the problem worse. That is why I'm thinking fuel problem?
Do you have a rear radiator?...it might be clogged up....does the temp gauge go up?....rear radiators require cleaning from time to time.
38,783 PostsLatest Activity: Sep 23, 2026
